PO Workflow in AX 2012
Hi Forum,
How to create workflow for PO.PO should be created automatically when we raise PR & confirmed RFQ.
I was successfully created workflow for PR with some conditions.Its working fine when it comes to auto PO workflow is not triggering.
Manually PR & PO workflow will work fine.
Please advise.
Rgrds,
Manju
http://daxing2012.wordpress.com/2013/01/16/automatic-creation-of-purchase-order-when-the-pr-is-approved/
Above link helps you. Also, you can search for the RFQ creation also in the same blog.
