I’ve been trying to use the schemas I got with the example BizTalk project shippedalong with the Commerce Gateway
the problem is that the at the end of the schema there is this sequence “Any” which contains this node that has no type
whenever I generate and instance from the schema using biztalk I fail validating this instance with the schema !!!
so I am unable to use this schema inside BizTalk projects
my questions are:
1- could anybody overcome this issue with the schema ?
2- is there a way to generate the schemas from Navision ? because we will be modifying the PO for exmaple by adding or removing fields so it does not make any sence to modify the schema manually !!!
I am using Nav 4 and BizTalk 2006
thanx in advance
