Please check your item and vendor for “lead time calculation”. Check the inbound and outbound handling times for the location you have entered in your sales order.
When they are all empty, you will see exactly the result you describe.
In this case the system assumes that you receive the same day you order the item. So there is no need for the system to order all 30 at once.
When you have a lead time entered in the item or vendor you will get the result you expect.
To get further information on this topic, do not hesitate to press F1 in your Navision and search for “Replenishment”. This will give you plenty of results and give you enough information to understand the issues.
So “When they are all empty, you will see exactly the result you describe” → it is correct.
I change “Lead time calculation” to 1M. And run planning again.
“When you have a lead time entered in the item or vendor you will get the result you expect” → it not correct, the result like when lead time calculation is empty.
If I use reordering policy : Order or Lot-to-Lot with not check Include Inventory : Planning worksheet will give the the result i describe.
If i use reordering policy : Fixed Reorder Qty, Maximum Qty, Lot-to-lot with check Include inventory : Planning worksheet will give the the result i expect.
