Planning Worksheet
When I select Calculate Regenerative Plan on my main machine, the worksheet is not populated with any journal lines.
If I then select Get Action messages it shows them.
On my local (laptop) NAV (local server) I get the journal lines after selecting Calculate Regenerative Plan.
Is there a setting somewhere that I need to change on my main machine that will make it behave the same as my laptop ?
Dave K.
Hi Dave,
You should be using the same database if it is to behave the same way. Or you should check exactly what setup is different in the two databases.
I’m sorry to give you such a “non-answer”, but unless we know exactly how you have setup your two systems, then there is now way to answer this.
