Hello,
Is there someone who knows if it is possible to run the master plan just for the raw materials and the production in AX2009?
I mean, I want the MRP to not consider the on-hand finished products and just plan taking into account the raw materials.
Thank you.
well if it did not plan the top level there would be no need for any raw material except from an already below safety stock. What are you trying to achieve and why?
Filtered running is not recommended, filtering the results is. However you can filter the run, so if your parent items are identifiable you can do it.
I am trying to plan the purchases of raw material (provisioning), but without taking into account the on-hand inventory of finished products.
So in the forecast scheduling, instead of the sales forecast what I introduce is the production forecast.
I want it to work this way:
-Item Z is composed by 2 A ítems, 1 B ítem and 3 C ítem.
-I have 50 Z ítems in the warehouse and I have planned that I need to produce another 40.
-I want the MRP to suggest me to purchase 80 A, 40 B and 120 C.
But if it works normally it would suggest me to do nothing because as I am introducing production forecast as if it were sales forecast, the MRP would consider that I already have 50 Z in the warehouse and I can sell 40 without producing anything more.
So I want it to not consider finished product in order to meet my production forecast requirements at stock level.
If it is not clear tell me and I can explain it again.
Thank you.
If someone has the same question as me this is the solution I have found out:
A new coverage group can be created and all finished products that are not to be considered are assigned to it. Then the positive days are set to 0.
If you plan now, all on-hand inventory of finished products won’t be considered.
