Planning for MPS
The planning result for MPS from blanket orders between version 3.60 & version 3.70 is different. In fact, it should be the same. Any ideas for this case? Scenario blanket No. 1 Item A 100 units, Due Date 01/08/04 Item A 100 units, Due Date 15/08/04 blanket No. 2 Item A 200 units, Due Date 01/08/04 Item A 200 units, Due Date 15/08/04 When I do planning at version 3.70, I got result: Item A 300 units, Due Date 01/08/04 Item A 300 units, Due Date 15/08/04 But the result from version 3.60 is: Item A 100 units, Due Date 01/08/04 Item A 300 units, Due Date 15/08/04 Why version 3.60 result, I got 100 units on Due Date 01/08/04 instead of 300 units.
Hi Difficult to comment without your settings and what you are expecting. Firstly you need to decide which one is correct [:D]. The altered the structure of the reordering policies between the two versions and 3.70 was essentially a massive patch for 3.60, so I suggest you have a look to see if this area has been altered, but ultimately decide which version has the correct processing for the settings you have.
