As per master planning output , Phantom item planned production order is generating with directly derived .
Due to huge Planned production order of Phantom Item , user are getting confused .
If I firm parent planned production order then this phantom Item is getting disappear . If I use manual coverage group then system is not creating demand of child Item.
Requirement :
System should not create planned production order of Phantom item but should create child item planned orders .
The phantoms have the word “dynamic” after them - AX uses them to peg the lower levels and therefore inherently needs them - it is only on the planning screen you see this, if you want “real” orders then it is not a phantom and you make it, otherwise you remove the confusion of the users by telling them what the screen means!
