Hello! I was wondering if there is any way that you can force a Label or TextBox placed in a Body section, to be printed at the bottom of the page of some report provided that there are no sections after this Body section? thnx, lp john
Hi! You could only the set the Property “PlaceInBottom” for “Footer”-Sections in Reports. Regards, Jörg
You could also fill the space above you “footer”-section with empty sections. You “just” have to calculate the space needed for the current page and print the right number of filler-sections. Why not using a simple footer?
Or use some combination of forcing a new page and using the TransFooter.
