Hi Every one,
I have a piece of code wrote in ax 2009
Can anyone help me write the same in AX 2012
Code wrote in SalesPackingSlipJournalCreate in Ax 2009
packingSlipVoucher = SalesParameters::numRefSalesPackingSlipVoucher().NumberSequence;
packingSlipNumber = inventLocation::find(this.packingSlipWareHouse()).AllePackingSlipNum;
if(packingSlipNumber)
return NumberSeq::newGetNumAndVoucherFromCode(packingSlipNumber,packingSlipVoucher);
else
return NumberSeq::newGetNumAndVoucher(SalesParameters::numRefPackingSlipId(),
SalesParameters::numRefSalesPackingSlipVoucher());
New method developer created
InventLocationId packingSlipWareHouse()
SalesParmLine salesParmLineLocal;
select salesParmLineLocal
where salesParmLineLocal.ParmId ==this.parmId();
return salesParmLineLocal.inventDim().InventLocationId;
Help me to convert it into Ax2012
Thanks&Regards
Raghu
This class is related to AX 2012. In AX 2009 this code will be handled in related form letter classes. (salesFormLetter, salesFormLetter_PackingSlip)
Hi Kranthi,
Thanks for reply,
I want to write that code in SalesPackingslipJournalCreate in AX2012 which is already there in SalesFormLetter_PackingSlip in Ax 2009
can u help me.
Thanks®ards
Raghu
It seems in AX 2009, you have modified \Classes\SalesFormLetter_PackingSlip\allocateNumAndVoucher
\Classes\SalesPackingSlipJournalCreate\allocateNumAndVoucher is the equivalent method in AX 2012.
Hi Kranthi,
Thanks for reply,
Yes what you said is right I wrote the code in 2012 SalesPackingSlipJournalCreate\allocateNumAndVoucher
packingSlipVoucher = SalesParameters::numRefSalesPackingSlipVoucher().NumberSequenceId;
packingSlipNumber = Numbersequencetable::findByNaturalKey(InventLocation::find(this.packingSlipWareHouse()).AllePackingSlipNum).RecId;
if
(packingSlipNumber)
return
NumberSeq::newGetNumAndVoucherFromId(packingSlipNumber, packingSlipVoucher);
else
FormLetter formLetter;
select
salesParmLineLocal
where
salesParmLineLocal.ParmId == formLetter.parmId();
return
Thanks&Regards
Raghu
