Hi there,
I am developing a page which has a picture field in it(I’m using nav 2013)
The problem is I want a way to restrict the size of the
picture that can be imported to this field.
I have looked in its properties but I don’t seem to find
any property for this.
I would be glad if somebody can give me some ideas of what
else to do.
Do you want to reduce the size of the control in the page (and not the size of the file imported), right?
In pages there is no direct control of field dimensions, the only idea I have is putting the image inside a GridLayout which should reduce the size.
Merci Daniele,
But how do I go about that ?
Thanks!
I will take a look at the urls and let you know the result.
Once again thanks for your response.
But one last thing, what if I want restrict the size of the picture file and not the control?
You can achieve this kind of result in NAV modifying Resolution attributes of .bmp file, like:
SetResolutionValue := DPIValue;
//Write horizontal resolution
BMPFile.SEEK(38);
BMPFile.WRITE(SetResolutionValue);
//Write vertical resolution
BMPFile.SEEK(42);
BMPFile.CLOSE;
You can refer to the following thread for additional informations: http://www.mibuso.com/forum/viewtopic.php?f=23&t=15403
