Picking Material in AX
is there any parameter that i can set to force the system to generate an automatic suggestion for picking material with respect of (Batch number and warehouse) using FIFO method
Regards.
There is no such parameter available. Needs to go for customization.
Ganesh B
thanks for your reply.
Yes you can do this
If you use reservation it will do this. If you do not use reservation and you select the reservation flag on the pick it will suggest batch, the warehosue depends upon sales order entry . The registration then confirms this.
