Physical Inventory Details
hi,
I need one help regards,. I want to store the particular date Physical inventory stock details in Temp table .(If its possible plz provide some Coding )
Palani
May I suggest that you add a bit more details to what exactly you want to do, including what you’ve tried so far, and what you then have a problem with. Otherwise the above question doesn’t make a lot of sense. [:)]
hi Erik,
We have standard report like Physical Inventory By inventory dimension ( Closing Stock or Op Stock for particular date), In this details same way i have to store in temp table.
I don’t have what are the tables to be involve this concept .Plz suggests me .
The Details will be like
Item Number Batch No Site Warehouse Physical Quantity
xxx1 1256 P01 P01-PRC 10
XXX2 5621 P01 P01-PRC 20
like this way i have to store.
Palani
Why you want to store the same in Temp table ?
You can use any buffer table for the same.
