Phantom item
There are two places in AX 2009 for phantom BOM. One is on the item details → Reference tab → Phantom check box. One is on the BOM component, the BOM line type, you can specify as a phantom. I was wondering how these two set up works together? For example, if I set up a BOM item as phantom in Item details, but item type in BOM line type. What would happen? Also, if I set up the BOM is not phantom in item details, but with BOM line type phantom?
Thanks in advance,
The BOM line is the one that is referenced. You could try it and see [:D]
