Hi, I have one problem with the rights. There is navision user who cannot access lets say table x but can access table y. When he tries to insert new record in the table y navision code in the triger OnInsert() has to access that table x(just for check). I tried to give indirect right for reading table x but it doesn’t work and user cannot insert new records in the table y. Does anybody has ideas about it ?
If you give the user the indirect right to read table x, you also need to give table y (direct!) read right to table x.
quote:
You’re right. In other words Set the permissions property for table y to acces table x.
That is not what he told you He was telling you to change the Navision User (Roles) rights. You just change permissions in a objects to acces an other objetc. Be careful with that!
quote:
Originally posted by eromein
That is not what he told youHe was telling you to change the Navision User (Roles) rights.
Huh? Who, do you mean, did not tell what to whom? My exact wording was “…give table y…”. Nowhere did I mention a role’s rights. Marco correctly explained in a bit more detail that these permissions had to be set on the permissions property of table y.
sry about that! It was late, And I had some glasses of wine, this could have influenced my reading abbilities
