permissions for client
I give the accounts payable module permissions in particular user group i get the following error
Not enough rights to use table ‘Inventory dimensions’ (InventDim).8182.1-18-2012 5-53-56 PM.png
my client cant view/generate anything like creating permissions though i gave full level permissions
i am unable find solution for this…
suggestions are accepted…
Check Miscellaneous under Accounts Payable, there may be hidden tables that you have restricted access to, this could prevent the user rights to this table.
Also I see you have restricted access completely on other Modules, this is a time consuming procedure and blocking access to everything will result in restriction problems.
