permission set
dear all
I have made a new permission set for my user.
whenever the user login it Navison it gives an error ‘Navision has stopped working’ and navision restarts. Please help.
Can you explain in detail about the permision use gave for the new user.
Bharath K
And, perhaps more importantly, which permission set(s) have you taken away - it seems likely you have removed one which is essential.
i made this permission set step by step on a test DB and it was working fine. each and every error was given about permissions and it was sorted , but it stopped working on the LIVE DB.
Should i mention all the tables and pages given?
Compile all objects, then try…
actually, I found the reason it was due to the fact boxes on the pages that were crashing. i gave the permission and it is all working fine.
