I have encountered a permission problem with a table using the LinkedObject property. The implementation is NAV4.0SP1 on SQL2005 with Windows Authenticated users.
The table view within the NAV d/b points to an external SQL d/b on the same SQL Server. Through NAV security, I have assigned “read” permission to the linked table and synchronized, and at the SQL level, that user has been granted select and execute rights to both the view (within the NAV d/b) and to the underlying tables (other SQL d/b) which the view points to.
From within NAV, when the user tries to access the linked table, NAV returns the message, “You do not have permission to read the… table”. However, accessing the view externally (e.g. in Excel via ODBC) the user is able to access the view.
I suspect that it may be associated to the application roles which are used by NAV ($ndo$ar$000…), though this is the limit of my knowledge on SQL security.
Can anyone help, please!
