hi all
i want to create Permission in Dynamics ax
when i set Permission for a user to full , not show this Permission for user:
for example i have a function button in Ax and it is full access but not Show in End User
hi all
Have you given the end-user this security group?
In the security menu set the top option to “Menu” and then go through the menu options and ensure the sub-form is switched on within the main form - this will make your button appear.
Finally one last piece of advice, you can download the “Security Profiler”. This tool will basically record every security step you take to carry out a process - its a needs must for security setup.
