Permission for Quick Search
I am creating some roles using the function provided in http://www.go-live.us/downloads.htm, and i noticed something which is very weird, the quick search stopped working! does anyone have any idea why and how can i change this, currently the users are using the SUPER permission but i will need to make some security policies as different types of users begin using navision soon. I am using Navision 4 SP1 with sql server 2005.
I am not sure what you mean by quick search. Do you mean the ability to search in non-editable find by typing in the field?
If yes, then this feature and be enabled / disabled from Tools → Options → Quick Find.
Do you mean just using the normal search (Ctrl+F)?
If yes, then this can be controlled by permissions. Go to Tools → Security → Roles. Select the role you want to change (Role → Permissions). Add the “2510 Edit, Find” system permission.
Regards
Claus
Hi Claus,
I mean both . I tried the first and it is enabled but doesnt work, i want to try the second but i do not understand what you mean by:
“If yes, then this can be controlled by permissions. Go to Tools → Security → Roles. Select the role you want to change (Role → Permissions). Add the “2510 Edit, Find” system permission.”
my role → permission table is empty. if that is what u mean
Hi Ziad
Go to Tools → Security → Roles. This screen (the role screen) shows you all the roles in the Database.
You said that all your users had SUPER permission. This normally means that the SUPER role is assigned to the users. The SUPER role has the below permission (Role → Permissions):
Object Type
Object ID
Read Permission
Insert Permission
Modify Permission
Delete Permission
Execute Permission
Table Data
0
Yes
Yes
Yes
Yes
Yes
Table
0
Yes
Yes
Yes
Yes
Yes
Form
0
Yes
Yes
Yes
Yes
Yes
Report
0
Yes
Yes
Yes
Yes
Yes
Dataport
0
Yes
Yes
Yes
Yes
Yes
Codeunit
0
Yes
Yes
Yes
Yes
Yes
XMLport
0
Yes
Yes
Yes
Yes
Yes
MenuSuite
0
Yes
Yes
Yes
Yes
Yes
System
Hi Ziad
My screen dumps disappeared when I posted the reply. I will try to upload them as a file instead.
Regards
Claus
Hi Claus,
Got it!
Thanks for your help,
Hi Ziad. This is not a finished product (as written in the disclaimer below). I only created it to help get someone started, its not really designed to be “ready to go”. [;)]
