My client facing a permission error while exporting any form data in Navision 2009 W1(Build 6.00.27808) using system button(Export To Excel).
The error says “You don’t have permission to read User Default Style Sheet Table”.
But when I check in the roles, only ALL role is assigned to that user and permission for the table exists and READ/INSERT/DELETE/MODIFY all are YES. The user have only Public role in SQL. I synchronized the user and try again and facing the same error. Also, when I included Table-Data (0) permission into the role, error doesn’t appear. When a super user exports, error doesn’t appear. Also, when I tested in my local system, the error doesn’t appear for the same role configuration both in SQL and Navision.
I don’t know why this is happening.
Thanks in advance.
