period Code field is missing
Hi All ,
In AX 2009 , i Ledger transactions itself has a field “.PeriodCode.” , which indicates the entry type is Normal, Opening and closing.
I have searched that field in AX 2012 in General journal Entry and General journal Account Entry. But this field is missing in the both tables .
Could any share me the field name in the AX 2012 and table name ?
What is the use the of General Journal Entry table in AX 2012 ?
Thanks in advance.
Consult Mapping the LedgerTrans table to General Journal Tables in any case like this. It says that you should use FiscalCalendarPeriod.Type field.
