Hello, I have serious problems of performance with Axapta. For example, the recording of a line of customer order spends several seconds. Would someone else have problems of performance? Do you know which parameters it is necessary to tune to speed up the recordings in the database? Thank you.
Hello Eric, do you still have the problems? Check the caching settings for the tables in Axapta. Maybe this helps. How are you connected to the AOS? 2 tier, 3 tier, WAN? Pirmin
