PDF Merge function
Hello,
Sometimes a customer requests their invoice by mail.
At the moment I print the invoice on our invoice paper, then scan the document and send it as attachment. This is too much work.
I would like to save the invoice as PDF, then merge it with our invoice paper and send it trough e-mail or send it directly by mail but always with a merged PDF file.
Whats the best way to handle this?
Search Mibuso for examples. there is bullzip and pdfcreator.
It would be a cleaner solution to re-create the invoice in AX so that it prints correctly on blank paper. This means, of course, that you would always use the blank paper from now on. You would end up with more flexibility and could create the PDF correctly straight out of AX without the need for an ancillary software and post process.
