PDF File resolution and image not correct
I am trying to make PDF documents from invoices, packing slips etc. Only problem is that if I create a PDF file from AX 2009, the resolution isnt correct and the image quality is poor. Everything is bigger in the PDF file so text overlap eachother etc.
Anyone else has this problem?
By default Ax uses default printer settings when you print or generate file from Ax. If you haven’t already done so, remove default printer and print a report.
I can make the PDF, problem is the resolution the PDF comes out isnt correct. The text is bigger then normal and the images are all distorted.
