I’ m facing errors while compiling the PayrollTaxEngineUti class:
Description | Path | Line | Method/Property name | Diagnostic ID |
Syntax error. | \Classes\PayrollTaxEngineUtil\checkInTaxEngine | 7 | checkInTaxEngine | Err:9999 |
Syntax error. | \Classes\PayrollTaxEngineUtil\checkOutTaxEngine | 7 | checkOutTaxEngine | Err:9999 |
Variable Symmetry has not been declared. | \Classes\PayrollTaxEngineUtil\getGNISLocations | 40 | getGNISLocations | Err:9 |
Variable Symmetry has not been declared. | \Classes\PayrollTaxEngineUtil\getMunicipalities | 39 | getMunicipalities | Err:9 |
Syntax error. | \Classes\PayrollTaxEngineUtil\getPoliticalSubDivision | 31 | getPoliticalSubDivision | Err:9999 |
Syntax error. | \Classes\PayrollTaxEngineUtil\getPoliticalSubDivisionByTaxCode | 20 | getPoliticalSubDivisionByTaxCode | Err:9999 |
Variable Symmetry has not been declared. | \Classes\PayrollTaxEngineUtil\getSchoolDistricts | 41 | getSchoolDistricts | Err:9 |
Variable Symmetry has not been declared. | \Classes\PayrollTaxEngineUtil\getTaxEngineLocationCodeList | 38 | getTaxEngineLocationCodeList | Err:9 |
Syntax error. | \Classes\PayrollTaxEngineUtil\getTaxEngineVersion | 10 | getTaxEngineVersion | Err:9999 |
Syntax error. | \Classes\PayrollTaxEngineUtil\getTaxTableVersion | 10 | getTaxTableVersion | Err:9999 |
Syntax error. | \Classes\PayrollTaxEngineUtil\money2Real | 11 | money2Real | Err:9999 |
Syntax error. | \Classes\PayrollTaxEngineUtil\real2Hours | 11 | real2Hours | Err:9999 |
Syntax error. | \Classes\PayrollTaxEngineUtil\real2Money | 11 | real2Money | Err:9999 |
Syntax error. | \Classes\PayrollTaxEngineUtil\real2Rate | 11 | real2Rate | Err:9999 |
Syntax error. | \Classes\PayrollTaxEngineUtil\taxCalculation2TaxCode | 11 | taxCalculation2TaxCode | Err:9999 |
I tried the following solution, but its not working for me…
In the AOT → References node right click and add a new reference.
click on browse and select the ste-net.dll and press ok.
Compile the classes.
Any suggestion please…
