Hi… I have downloaded the hot fix ( with folder name: 20040709Payroll3.7IN_Objects) from the Navision ftp site . After I imported it into the database I am not able to set the ‘Pay Elements’ for the employee. It gives the following error… " The definition of the field Salary Processed was changed after the object was saved. Old Type: Boolean New Type:Option " It gives the same error, when I click on " Monthly Payroll Process" Menu Item in Periodic Activities. Please Suggest
Hi, You need to compile your objects.
