Payment attach multiple invoices
I need some help to settle my invoices with x++ in axapta ax4
static void LedgerJournal(Args _args)
LedgerJournalName LedgerJournalName;
LedgerJournalTable ledgerJournalTable;
LedgerJournalTrans ledgerJournalTrans;
LedgerJournalCheckPost ledgerJournalCheckPost;
NumberSeq numberseq;
LedgerJournalNameId LedgerJournalNameId = ‘GenJrn’;
BankAccountID BankAccountID = ‘EUR OPER’;
ledgerAccount offsetAccount = ‘601500’;
amountCur amountCur = 102;
ttsbegin;
// Find a ledgerJournalName record
select firstonly LedgerJournalName
where LedgerJournalName.JournalName ==LedgerJournalNameId;
//Created the ledgerJournalTable
ledgerJournalTable.JournalName =LedgerJournalName.JournalName;
ledgerJournalTable.initFromLedgerJournalName();
ledgerJournalTable.Name = ‘Hotel’;
ledgerJournalTable.insert();
numberseq =NumberSeq::newGetVoucherFromCode(ledgerJournalName.VoucherSeries);
ledgerJournalTrans.Voucher = numberseq.voucher();
//Generate the transaction line
ledgerJournalTrans.JournalNum =ledgerJournalTable.JournalNum;
ledgerJournalTrans.CurrencyCode = ‘EUR’;
ledgerJournalTrans.ExchRate =Currency::exchRate(ledgerJournalTrans.CurrencyCode);
ledgerJournalTrans.AccountNum = BankAccountID;
ledgerJournalTrans.AccountType =LedgerJournalACType::Bank;
ledgerJournalTrans.AmountCurCredit = amountCur;
//Pass the Date . You can also use str2Date(‘08/08/2008’) if period is not defined.
ledgerJournalTrans.TransDate = today();
ledgerJournalTrans.Txt = ‘Room Stay’;
ledgerJournalTrans.OffsetAccount = offsetAccount;
ledgerJournalTrans.OffsetAccountType =LedgerJournalACType::Ledger;
ledgerJournalTrans.insert();
info(strfmt(‘Journal Id:%1’,ledgerJournalTable.JournalNum));
//Post the Journal
ledgerJournalCheckPost= ledgerJournalCheckPost::newLedgerJournalTable(ledgerJournalTable,NoYes::Yes);
ledgerJournalCheckPost.run();
ttscommit;
/*while select ledgerJournalTrans order by recId desc
where ledgerJournalTrans.DocumentNum == localJournalTrans.DocumentNum
custTransOpen = CustTransOpen::findRefId(CustTrans::findVoucherDate (ledgerJournalTrans.Voucher, ledgerJournalTrans.TransDate).RecId);
//check correction payment
amountSettled = abs(custTransOpen.AmountCur);
//get amount
if(ledgerJournalTrans.AmountCurCredit > 0)
amountReceived = abs(ledgerJournalTrans.AmountCurCredit) *-1;
if(ledgerJournalTrans.AmountCurDebit > 0)
amountReceived = ledgerJournalTrans.AmountCurDebit;
//create settlement based on custTransOpen
specification = Specification::construct(SpecType::OffsetVoucher, localJournalTrans.TableId, localJournalTrans.RecId);
specification.create(custTransOpen.TableId, custTransOpen.RecId, amountReceived, localJournalTrans.CurrencyCode, NoYes::Yes);
i got this code of the internet the bottem part i suspect settle invoices but i need some sort of while en i think this code is for 2009.
Please help
