I would like to know if anyone has modified the Check Report 1401 so that standard navision can print MICR checks. I would appreciate it very much if someone could share with the information on how to get this done. Our checks have two stubs and with the check in the middle portion. Thank you.
Please search the forum for print micr check. You will find the information you are after.
Thank you Nelson. I found the information by searching the forums.
Hi, I just want to add that you do not need printer with magnetic inc. Banks can process checks printed on normal printers.
