I’m changing the Table filters (for calcformulas) for hundreds of fields throughout the system, as you might expect it’s a very boring and annoying job but not being able to PASTE make it even more painful. Message to Navision A/S : Pleeeez make it possible to paste data into table filter in your next version Thanks! A bored Tarek (My fingers hurts!) tarek_demiati@ureach.com
Keep with cheese whiz !!! I remember the times then realised NF 1.30, and NF told that in the next ver in design will be able search thru table & field list. Now realesed witch ver ? NF is not tool for developrs it’s for acounting !!! regards, headache Dalius
Hi Tarek I backup the objects, then Export as Text, sometimes I find and replace others find and edit, then I Import the text file! I thought you may like to know that Graham at MindSource is looking to create some new Developers tools within Navision, one being an Automation Type Viewer the other a tool that will expose the table and field properties. When they are completed they will be made availible for download FOC. Mr David Cox MindSource (UK) Limited Navision Solutions Partner Email: david@mindsource.co.uk Web: www.mindsource.co.uk
