Passing parameter to dataport
Hello,
I would like to export some records using dataport.
I have a form (Header) with a subfrom (Lines). I want to export records from Lines, filtered by a field from Header.
In dataport I use Lines as DataItem. I have a function in dataport:
SetCode(Code : Code[10])
BTCode := Code;
I call the dataport from menu item on the form like this (dp is the dataport, Code is the field of the Header, which I use for filtering):
OnPush():
dp.SetCode(Code);
DATAPORT.RUNMODAL(50010);
After trying this, BTCode is empty, the parameter is not passed to the dataport.
Any idea about what I am doing wrong?
Thanks a lot, Frida
OnPush()
Purchline.RESET;
Purchline.SETRANGE(“Document Type”,“Document Type”);
Purchline.SETRANGE(“Document No.”,“No.”);
Purchline.SETRANGE(Purchline.Type,Purchline.Type::Item);
DATAPORT.RUNMODAL(50010,TRUE,Purchline);
*Code assumes it’s from a purchase order. If Sales Order change PurchLine to SalesLine.
Save->Compile->Enjoy!
