Passing filter paramteres to report
hi everyone,
i would like to pass a parameters (filters) from form to reports, but unfortunately my reports are using only integer data item,
based on the filter set from forms (eg: g/l accnt, dimension views) i would then run the reports, customs the column layout/ caption accordingly prior to export to excel.
Did you try by creating a function in report and passing filters via that funtion before running the report?
hi mohana,
resolved it already, i cant call the functions and passparameters as i run the report calling the request forms… how silly
meaning… i cant call the functions, because in another line i am running a report, with calling request forms set as yes in the report.run parameters…
