first thing in the init() method of the report yout getting the combobox value…check that once…
sorry for late
how i getting the combobox value…check
which function i need to write in init() method
thanks for help
hi mr Naresh Kolli
i don’t no u said when i declare the s in class declaration i can use the s value and it read from init() method
if u remember we write like this in parameter function
S = element.args().parm();
i hope to help
thanks for u help
hi Naresh Kolli
could pls answer my last 2 question
thanks for ur help
Naresh Kolli
maybe i find what the wrong
in click void clicked()
we have 2 parameter
1- args.parm(EN_AR.valueStr()); combobox parameter
2- args.parm(CheckIssue.CheckIssueRef); serial_no parameter
in our code we Write like this
void clicked()
{ str sNote_Ref ;
str sEnum ;
int nCoun_Check ;
CHECK_NUMBER_TABLE CHECK_NUMBER_TABLE1;
SUM_CASHISSUEDETAIL_View5 CheckIssue1 ;
Args args = new args();
ReportRun reportRun;
while select * from CHECK_NUMBER_TABLE1
where CHECK_NUMBER_TABLE1.CheckNumber == CheckIssue.CheckNumber
nCoun_Check=CHECK_NUMBER_TABLE1.count_check ;
if ( nCoun_Check >= 1 )
if(EN_AR.valueStr() ==‘EN’){
box::warning(“This Report Was Print.”,“PRINT”,“Help text”);
else
box::warning(‘تم طباعة هذا التقرير مسبقاً’,‘الطباعة’);
else
while SELECT CheckIssueRef from CheckIssue1 where CheckIssue1.CheckIssueRef==CheckIssue.CheckIssueRef
sNote_Ref = CheckIssue.CheckIssueRef ;
args.parm(EN_AR.valueStr()); -----------\\\ first argoment from combobox ----------- ------ ------ ----- -
args.parm(CheckIssue.CheckIssueRef); -----------\\\ sec argoment from serial_no----------- ------ ------ ----- -
nfo(args1.parm());
// info(EN_AR.text()) ;
// info(num2str(EN_AR.,0,0,0,0));
// if(EN_AR.valueStr() ==‘EN’){
args.name(reportstr(CHECKISSUE_Report));
// else {args.name(reportstr(CHECKISSUE_Report));}
reportRun = classFactory.reportRunClass(args);
reportRun.init();
reportrun.run();
super();
in code reading last argoment-parm mean secn
i make test whith info to see i put info function like this
info(args1.parm());
in messag box give me value from combobx
but if i put info function after 2 argment like this give me sec argment
info(args1.parm());
in messag box give me value from serial -no
that mean parameter s pass the serial no becuse when i made if statement give me only after else it readin the parameter from s
serial -no field not from combobox
how we can read the 2 parameter from form to report 1 from combobox to s
other one from serial -no field together and send to report
thanks for help
HI Bas,
Hi Bas,
in the clicked method…
args.parm(comboBox.valustr()); //passing the combobox value
args.record(CheckIssue) // passing the table record so in the init method you can get the table buffer so there you use tablename.checkIssueRef
in the init method
s = element.args.parm() //getting the combobox value and storing in the global variable
locCheckIssue = element.args.record; //declare the table buffer of [CheckIssue locCheckIssue] in the init method and assigning the record to that buffer…
**this.query().dataSourceTable(tablenum(CheckIssue)) .addRange(fieldnum(CheckIssue,CheckIssueRef )).value(**locCheckIssue .CheckIssueRef);
try this it will work…
Naresh Kolli…
First, I’m sorry to bother you
but i have problem maby i have something miss understand
i make tow reports to give me the right resault
1 - first report reading AR from cobobox in arabic
iCheckAmount = SUM_CASHISSUEDETAIL_View5.SumOfAmount ;
sTafqeet = Global::numeralsToTxt_AR_LA(iCheckAmount);
2 - sec report reading EN from cobobox
sTafqeet = Global::numeralsToTxt_EN(iCheckAmount);
2 repot i want to but in function pls help to found miss understand u said for me
i can use s from Declaration class to use
if statmen like this
if (s =‘AR’)
else
but s coming empty and reding only after else
i am sorry again to bother you
but i need ur help & finsh this problem
thank for ur help
hi Naresh Kolli…
hi mr
i change every thing u write here
in the init method
about display str amt2txt() the problem it in this function we i call report
no need to change any thing in this function
public class ReportRun extends ObjectRun
str S ; here i declare S to make value and to complected call parameter (args.parm(comboBox.valustr());) in display str amt2txt()
} to S
{str ParmCaller ;
str sTafqeet;
int iCheckAmount ;
while SELECT SumOfAmount from SUM_CASHISSUEDETAIL_View5
where SUM_CASHISSUEDETAIL_View5.CheckIssueRef==CheckIssue.CheckIssueRef
if (S==‘AR’){
else
CheckIssue_BeneficiaryName.alignment(1);
return sTafqeet;
pls if u see any change need to add in this function send to me to make right function
thank u for every help and i am so sorry agian
i am a new in this lang becu i have many question and miss under stand
hi mr .Naresh Kolli…
did u check my question no need to change in 2 this function
if function is right way no result
thanks for help
i thing this will last question here pls
this will last step in this question
maybe u have more Experience in this language u
why no answer
thanks for ur help
Hi.
To get combobox selected value, try it by writing your code in combobox modified method as
public boolean modified()
boolean ret;
ret = super();
info(this.valueStr());
return ret;
