pass the field values from one form to another
hii all,
How to pass the field values from one form to another form.
say we have SalesId,CustName,Qty in one form, when we enter values in these fields and click ok, these values should refelect in another form which contains these fields(SalesId,CustName,Qty).
You can use Args to pass the values from one form to another form.
  1. On the clicked method of the button in the form you can construct the Args
Args args = new Args()
ContainerClass formValues;
Container conSend;
conSend = conins(conSend, 1,salesLine.salesID);
conSend = conins(conSend, 2,salesTable.custName);
conSend = conins(conSend, 3, salesLine.qty);
formValues = new ContainerClass(conSend);
Args.parmObject(formValues);
  1. Pass the value
new MenuFunction(menuitemdisplaystr("Receiving Form Name"), MenuItemType::Display).run(args);
3. Receive values in the other form's init method
 	public void init()
	 containerClass conClass_Obj;
	 container conRec;
	 Args args;
 	 super();
 	 args = new args();
 	 conClass_Obj =  element.args().parmObject();
 	 conRec = conClass_Obj.value();
        // assign to respective fields
         conpeek(conRec,1);
 	 conpeek(conRec,2);
 	 conpeek(conRec,3);
Raghav.
The following link might help you : http://www.axaptapedia.com/Passing_values_between_forms
hope it helps
regards,
Thomas
