Parameters to display
Hi
I created a report(standard) customer balance from custtrans and custtable.
all the informations displayed. report filters, custid, posting profile and transdate (from and to) 01-04-2011…20.04.2011
how to display that transdate in report header
ay one help me.
Saravanan.R
You can write a display method for transDate and return the transDate from the method.
return strfmt("%1…%2"fromDate,toDate);//fromDate and toDate are selected filter dates
Thanks Vinay for your quick reply
i tried, but syntax error
display Transdate bydate()
return strfmt("%1…%2" fromDate,toDate);
give me your reply.
thanks
Saravanan.R
You forgot to put comma just before fromDate.Moreover the method should return a string.It should be as following
display str bydate()
return strfmt("%1…%2",fromDate,toDate);
Thank you sir
i tried no error message, but display only … (double dots)
By
Saravanan.R
It is happening because the fromDate and toDate values are blank.You need to initialize the values before running this method.
Sorry for disturbing you, i am new to this, how to initialize the values
here that third one, i need to print this to in my report header
Advance thanks
By
Saravanan.R
Hi
Any one pl help
