Page
Hi All
is it possible to add button on a page. If it isn’t how can I disable some action (ex. some action under Related Information)
Button means we can add action and Promote it…
To Disable, Open Page in design mode,
Select last blank line, click View–>Page Actions
Select Action, set Visible = FALSE
but I need to do that with code ( if certain conditions are met then action is enabled, otherwise not)IF…Action enabled else action disabled
I need this code wich appears in the form to be modified for page
IF … THEN
CurrForm.SomeButton.ENABLED(FALSE)
ELSE
CurrForm.SomeButton .ENABLED(TRUE)
You can add a boolean variable with IncludeInDataset to yes(in properties)
and add the boolean in Action Visible Property
Write your codition in OnOpen Page…
I guess it works only from OnOpen Page…
Mohana
Is it possible action to be visible but non functional. so
If…Then Action functional
ELSE
Action non functional but visible
You can check the condition onPush trigger of action and ececute code if condition true…
