Page
I am new to Nav development - I am trying to write an Action in the Role Center that then opens a page. This page has an OnOpenPage() trigger that then calls some test code of mine. I set the Action to run the page correctly (it is id 50000), but when I click the action in the RTC, I get the error:
Object of type Page with id 99000833 could not be found.
Can anyone help?
Thanks!
i am unable to get you.
What you did
a) You Modified the Role Center Page of RTC.
b) You Created a Page and want to Run it.
c) You Created two Pages and from one page you want to run the another page.
I modified the role center, by adding an Action. This action should then run my new page.
did you assign runobject and promote it properly?
hi adam
can u share ur code to us…
so that we can easily solve ur problem…
I tried same on my Nav 2009.
I modified the Page 9019 “CEO and President Role Center”.
I added a action in action designer with caption “PageRun” and RunObjectProperty to “Page XYZ”.
I started NAV RTC and clicked on the page in the navigation bar , its working fine.
I haven’t modified any other property other than what i mentioned here.
You get this message when either:
  1. The object has not been saved in compiled form.
  2. The database has not been enabled for a NAV Server (in File/Database/Alter/Options).
Since you are otherwise using the RTC ok, I suspect that it must be 1 not 2.
Can you check that? Also, try to find the object in the Object Metadata table.
