I try to create a custom lookup for my dialogField however no lookup opens when I click dropdown.
Here is my code.
protected Object dialog()
Dialog ret;
ret = super();
dlgOperatorCode = ret.addField(extendedTypeStr(LGSPerformerCode), '', '', true);
dlgOperatorCode.value(operatorCode);
if(dlgOperatorCode.value())
dlgOperatorCode.enabled(false); // Make it read only when default value is set
dlgOperatorName = ret.addFieldValue(extendedTypeStr(LGSName), operatorName);
dlgOperatorCountry = ret.addFieldValue(extendedTypeStr(AddressCountryRegionId), operatorCountry);
dlgOperatorCountry.registerOverrideMethod(methodStr(FormStringControl, lookup), methodStr(LGSCreateOperatorDialog, countryLookup), this);
return ret;
and my lookup (I know it looks simple enough that i woudnt need custom, but I reduced it to a minimum for this case):
public void countryLookup(FormStringControl _control)
SysTableLookup sysTableLookup;
sysTableLookup = SysTableLookup::newParameters(tableNum(LogisticsAddressCountryRegion), _control);
sysTableLookup.addLookupfield(fieldNum(LogisticsAddressCountryRegion, CountryRegionId));
sysTableLookup.performFormLookup();
Both methods are in the same RunBase class (LGSCreateOperatorDialog). I think I’ve tried looking at every related google result twice. I tried CIL build, refreshing elements etc. Nothing works.
Sometimes when I recompile the class I get "
Error executing code: FormStringControl (object), method Lookup called with invalid parameters.
Stack trace"
but then I compile it again and no errors.
