Hi, I have Navision 2.0. How do I print on the page without creating a new page. I just need to print several record on the same line without running separate table view and loading things into variables. thanks
If with pages and lines you mean sections in a report then you can put in needed section a control with SourceExpr like this: DataItem.Field
But I’m not sure I understood your problem.
I have var in the table. I total have 3 records. On ther report in need to format it like this: rec1.var rec2.var rec3.var
Have a look on the labels report… it will help you
