After a merge activity using ODT, some controls on Forms or reports could results overlapped. To find/fix this bug we need to ‘manually’ compare forms and reports. Is there any tool/procedure to automatically find overlapped controls? Thank you,
Hi. There is a report you can run from the Dev.Toolkit. Or at least it was. There was a function button on the bottom of the screen but I cant find it right now. If you are in a merge project you should be able to see it. I can’t imagine they have taken it away. Good luck.
