Hello,
In the Load planning workbench, I have a Load with status ‘In Process’. All its lines ‘Work status‘ say ‘100% of work completed‘. In the Load header, under ‘Related Information/Work details’, I clicked on ‘Work details’ to view the Work header statuses. There are two work orders, and one of them, Work Order A, has its header and lines have closed statuses. However, the second work order B has its header status as ‘In process‘ and it has 6 lines. Out of those 5 pick lines and one Put line. All the 5 lines are in the closed status and the Put line is in the Open status.
When I try to complete that work order B, which is in In-process status, it is throwing the subject line error ‘Overdelivery of line is 100.00 percent, but the allowed overdelivery is only 20.00 percent.’Overdelivery of line is 100.00 percent, but the allowed overdelivery is only 20.00 percent.’
Here is the screen shot of the error. When I select the error in the info log window then I would see an ‘Edit‘ button in the bottom of the window on the left side of the ‘Cancel’ button. But I don’t see it in the scenario. When I debug, either it doesn’t stop the exact line where it is throwing the error or I am some how passing the specific class and the method and it finally puts the message in the info log.
I am not sure how to go about finding what is causing the issue and which class and method it might be throwing the error from.
Any inputs/help are appreciated.
Thank you!
