Hello all, i am fairly new to using and administrating navision, so i am having some issues.
1- Outlook integration: i cannot get it to work, I am using the administrator account for this, i log into outlook, go to configuration options for the navision synch and set the server/database/company names (it auto finds them after i type in the server IP, and then i hit the test button, i get the message
“the response from MS Dynamics NAV has not been recieved because of connection timeout, please check if the MS NAV server is running and try again later, if the problem persists increase the timeout value in the configuration file. please verify your synch settings, if problem persists contact admin”
I have checked the settings, increased the timeout and the server is running, what am i missing here?
2-Email Marketing campaigns: our marketing department, is trying to initialize marketing campaigns through NAV, but the only problem is when they attach an HTML newsletter, it shows in the attachments and not in the body where it is intended to be, is there anyway to get the HTML into the body of the message? thank you
the option is already “unchecked” and to make sure i tried it again and it’s a no go.
the problem is, if i attach a HTML newsletter it goes, but as an attachment, i want it in the body, maybe i am doing it wrong, maybe i shouldnt attach it? how to insert it in the body… and be viewed by the recipient in the body.
