Hi, Using Attain 3.60 - Has anyone ever created a self-contained piece of code to create an appointment in outlook from within Attain without going through the whole CRM Outlook Synchronization process? Any assistance is appreciated. Thanks.
Yes. I used to do it in the days before we had Outlook sync. Its very simple. Just create a variable of type AUtomations::Outlook, All the comands are there, and it will only take you a few minutes to get a simple sample working. If you need help fo rht ecommands, then go to Outlook installer, and install VB and VB help. Then find the help file, and in this you will find the paramaters etc. for the functions.
