Hi Harish Mohanbabu ,
As per your Guidence Outbound exchange is working fine.Inbound Exchange isnot working.
Created Local Endpoint - default to company Company - DAT Local endpoint - VillageLocal. Transport Adapters Adapter Class - AifFileSystemAdapter Name - File System Adapter Active - Yes Direction - Receive Or Send3.Channels Channel ID - Test Name - File System Channel Active - Yes Adapter - File System Adapter Direction - Outbound Parallel Processing - No Address - F:\Test Folder\ Response Channel - Channel ID - Test1 Name - File System Channel Active - Yes Adapter - File System Adapter Direction - Inbound Parallel Processing - Yes Address - F:\Test Folder 1\ Response Channel - Test. Endpoints Endpoint ID - VillageEnd Name - Item Inbound Active - Yes Propogate Errors - Yes Intercompany Organization - No Outbound channel ID - CHN003 Local endpointID - VillageLocal No Contraints Users - User group - Admin - Administrators Action Policies for this Endpoint Action ID - InventItemService.find Is default policy - No Status - Enabled External identifier override Class Name - InventItemService Logging mode - Log Original {Datapolicy - required all enabled fields
My JOB,
AifGatewayReceiveService.run();
AifInboundprocessingservice.run();
I debug the code line by line.
after execution of first line
the xml file in Inbound folder is disabled and Queue Manager shows the details as
Channel - Test1,Direction - InBound,Status - Ready,Source EndPoint -Village Local,Destination EndPoint - Village End
After execution of second Line
Queue Manager
Channel - Test1,Direction - InBound,Status - Error,Source EndPoint -Village Local,Destination EndPoint - Village End
Error message ->Endpoint villageLocal does not exist or is disabled.
In Exception form shows the details as
Exception - Error ,Module - AIF,Sub System - AifRequestProcessor-processServiceRequest,Exception Message → Endpoint villageLocal does not exist or is disabled.
please tell me where i did a mistake.Thanks in advance.
