Ordertracking (ATP / CTP)
Hi All, At the moment we are struggling to implement a time factor in the Ordertracking CU’s of Navision. Instead of having a date of shipment and a date of delivery, we are adding a time to it… I know what you are thinking… It is mad, but it’s a customer’s whish… Anybody any helpfull thoughts… By the way, the Toolkit doesn’t help that much as well…
Sven, How are you using the toolkit in this instance? In the past I have found it very useful in similar situations. Eg. Search the objects for where the field of interest is set with ‘“Planned Delivery Date” :=’ or ‘validate(“Planned Delivery Date”’. This should give you a list of objects which will contain the code that does the ATP/CTP calculation that you will need to supplement with the time parameter. Good Luck, Chris.
