Hi,Experts…
I am totally new to Navision,Please need a help
Is there any functionality or program or any concurrent program with in navision for the Order status,Shipping status ,invoice notices which automatically changes status when we run in backend
Any xmlport or any Dataport or any Codeunit to run within navision to update the order status,shipping status and invoice status.
Thank u all…
No such kind of back end program not available in Navision . You need to build the same
Whatever status available on Naivison is change according to process .
Hi sir,
Just i will go with one example to understand my issue.
A order is booked from e-commerce web (magento) and it transferred to Navision via Sterling integrator(SI) and if the client wants to know where the Order response ,Invoice status,Delivery Notices is resided ,in these scenario ,what is the import/export functionality in navision that automatically updates the status…
Thanq…
For Sales order Navision has Status field which contain Open ,Released etc status. You need to add the options in this field or create another field for customized status and update it according to your process.
First of all, why you need to change the status? If there’s a manipulation of process, then Navision will change the status. If the case is that during import, those status you mentioned should already been changed, then you will work on your SI where these status should be already what you want before the import into Navision.
Nevertheless, these status play a part to identify if related documents are in progress or posted etc. If you really know what you are doing, changing the status by batch can be easily achievable by a single SQL Statement, you can write a script, you can write a dot net application to achieve that, plenty of ways.
