Hi Can we change option string at run time? or what are the alternative methods by which we can handle it?[?] [:)] regards [8]Rajan
No, it can’t be done. see http://www.navision.net/forum/topic.asp?TOPIC_ID=7733
if you need to change an option it is only possible if you use it as lookup. Then you have the possibility to change the entries in the lookuptable.
