OPENING NEW DATABASE IN RTC
hi all,
i have installed trial version of navision in my office and the default database is opening in RTC, after that i have created new database using nav classic with ms sql server then restored the back of file in that and restarted navision again its opening in nav with sql server, then in CustomSettings i have changed the database name and when i am trying to open it in RTC its not opening, can u please help me out of this problem, i need information in step by step process, i am just go to wait for ur reply…
Is it throwing any error message? Did you try by Stopping the services and starting again?
What is the content of the backup that you restored? Did it contain multiple companies? And what about users? Any of these defined?
i just took back of default database and created new database with a new name and restored that back up file in the new database and i haven’t defined any user yet
Clear, so that should be of no relevance.
Then what about
yeah its throwing any regarding meta data
Can you show us exact error message?
Did you try by Compiling all objects?
ill get back to you
i am getting this error when i am trying to connect RTC with new database… and please see the error in getting in image below…
Did you try by compiling all objects?
Compile all objects…
tell me how to compile the object ?
how to compile all the object?
[:O]
Open Object designer
Click All from Left side options
Click Ctrl+A which selects all objects
You can select tools–>Compile or simply F11
Hi Mohana,
As you said me to compile the all the object in object designer, i did what you said me to do, after compiling the all the object i’m getting some errors. please see the image below of error list after compiling all the objects.
5758.nav error list.bmp (2.25 MB)
Can you try now to connect RTC…
i tried it but its it still showing error, see the image below.
8424.error in rtc.bmp (2.25 MB)
Because of the Menusuite error messages in your Compilation…
Which License are you using?
Are you super user?
default one its trial ver.
Upload your Partner License and try…
