Greetings. How to open multiple user ax application in single system?
(To be more clear) → Consider, I am user named A. I have to open ax application in the name of user B and so on.
Kuppusamy S
Kuppusamy S
I don’t think that is possible as ax depends on windows authentication for running the application.
Pranav…
You can use ‘Run as’ functionality (right click on AX under programs > select run as) to run AX as different users.
You can also use ‘Run as’ from code which is used in standard AX. This might help - http://msdn.microsoft.com/en-us/library/aa893873.aspx
Hi Pranav,
I am ready to provide credentials if it asks to open the application.
Kuppusamy S
Hi Harish,
Is it possible to open by providing credentials in command line interface?
Kuppusamy S
There is no command.
As I mentioned earlier, right click on the AX program link and select ‘run as’. If you are in doubt, Google for ‘Run as’
You Can Do MSTC For Opening Multiple Ax.
U can use the AX32.exe from the command line to open the AX directly.
Vikas Mehta
