Hi All
How i can see the opening balance report of the inventory. Please advise
thanks
Hi All
thanks
Is this in AX 2009 / 2012?
Also when you say “see” do you mean find on the menu and run the report, or actually open it up to modify in the AOT?
It is in 2009, actually i want to generate the report to know the opening balance of the inventory.
thanks
What do you mean by Opening balance report ? Generally every month closing balance is nothing but opening balance of Next month .
From which report i will get this feild mean opening balance column in the report
I suggest you play with standard reports , that you would come to know.
take a look at these reports
Arun.
