open window explorer from Navision
I am using report to create a report as well as exporting(writing out) a text file. I’ve got it all working except user has to type in the filename for the export file instead of using explorer like the normal dataport does. Could anybody tell me how to write the code behind the AssistButton Click?
Check out codeunit 412 (Common Dialog Management) in Navision Attain. Kind regards, Jan Hoek Weha Automatisering BV Woerden - The Netherlands
quote:
Originally posted by jhoek: Check out codeunit 412 (Common Dialog Management) in Navision Attain. Kind regards, Jan Hoek Weha Automatisering BV Woerden - The Netherlands
Hey, Jan, thank you for the quick response. Looks like I can call the codeunit for the function. I will give it a try :slight_smile:
